  #1
Old October 6th, 2004, 08:39 AM
fishie1 fishie1 is offline
Default Yamaha 97 200SWS alarm
Folks, please help. The alarm on my port engine came on when running at ~4200 rpms. There was oil in both tanks and the telltale was strong. The engine never faultered, hesitated or dropped rpms. It was warmed up sufficiently and ran at idle for about 10 minutes prior to this as we came out of the channel. It ran fine for several minutes before this occurred. There was no obstruction around the intake. After shutting the motor down, cussing excessively and checking for the oil and obstruction it started fine and ran for a minute or so before having the same problem. I shut it down, cussed some more and tried it again. Same results. After realizing that cussing aint gonna solve the problem I left it off, trolled home on one motor and turned it on at the marina to dock. No alarm since the rpms stayed low. The gauges never changed nor reflected any unusual condition.My question is what would cause the alarm in this manner? If the telltale has water flowing is it still possible for the water pump/impeller to have a problem? Could this be related to something else alltogether? Any thoughts,insight or suggestions would be appreciated.Thanks in advance.
  #2
Old October 6th, 2004, 12:08 PM
Divnnc Divnnc is offline
Default Re: Yamaha 97 200SWS alarm
What type of alarm? Was it a constant alarm or was it a series of beebs?
  #3
Old October 6th, 2004, 12:16 PM
It was a constant sound.
  #4
Old October 6th, 2004, 04:01 PM
Osprey Osprey is offline
Most likely you have a bad impeller. Yamaha's have a drift key on the main shaft that locks into a slot in the impeller. The drift key can break loose and/or tearout the inside of the impeller. The result is the blades on the impeller are likely still intact, so at low RPM's the impeller catches and pumps but at higher RPM's the main shaft spins inside the impeller.Next most likely causes:1. Stuck thermostat.2. Stuck poppit valve.Time to pull it apart and see.
  #5
Old October 7th, 2004, 05:27 AM
rodbolt rodbolt is offline
hello the 97,98 models had some impellers that would seperate from the hub. yamaha would not admit it but I saw more impeller failures from those years than all other motors combined. when it seperates it will pump to about 3000 then quit.what did the visual idicator on the tach show when the alarm was going off? good luck and keep posting. PS retorque the cyl heads as well.
  #6
Old October 7th, 2004, 07:13 AM
Thanks guys. The tach did not change at all.
  #7
Old October 7th, 2004, 02:03 PM
do you have the digital yamaha tach or did someone rig it with the bogus stuff?. if set up correctly the tach will indicate which alarm is giving the tone. good luck and keep posting
  #8
Old October 8th, 2004, 05:13 PM
tonydwood tonydwood is offline
When mine did this N0 5 piston was melting! a compression check may help. cheers
  #9
Old October 9th, 2004, 03:16 PM
Thanks for the help- just got back from the boat. The motor warmed up, idled and then ran at 1500 RPMs without a problem, and the tach read normal. As soon as I attempted to get up on plane (~3200) the alarm sounded. The tach had three arrows flashing abbove the red, yellow and green. There is oil in both tanks, with the onboard tank about 1/3 full. The manual oil switch did not run the pump when the motor was off- should this run anytime. Do I need a new oil pump on the remote tank, clean the filter or is this something else?
  #10
Old October 10th, 2004, 03:25 AM
the three flashing bars are telling you the system has a malfunction. if you have oil in the remote tank and not in the engine tank something went wrong. normally this is caused by a clogged oil filter in the remote tank. the fact that at low speed it will transfer oil and reset the alarm but at high speeds its using oil faster than the clogged filter can transfer it. the key must be on to use the emergency switch. when was the last remote oil tank filter service? good luck and keep posting.
  #11
Old October 10th, 2004, 06:00 AM
Thanks for the explanation. I bought the boat used earlier this year so I do not know when the filter was last serviced. Is this as easy as just replacing the filter and something I can do myself?
  #12
Old October 10th, 2004, 08:57 AM
to replace the filter remove the oil tank cut 2 wire ties and replace it. reverse the procedure and try it again
  #13
a clarification remove the REMOTE tank
  #14
Old October 11th, 2004, 02:00 PM
rodbolt- thanks for the help. Given that this was a holiday weekend and there was a local boat show I was not able to obtain a replacement. One dealer did say that I could try cleaning the existing filter as this usually works. I did so (it really wasn't dirty and did not appear clogged) and then proceeded to check the strainer on the onboard tank. That too looked very clean. I put everythin back together.I then, with the key in the on position but the motor not running, attempted to fill the onboard tank using the switch on the motor. Nothing happened- no motor sound and no oil pumping. Does it sound like I need a new oil pump or is there somthing else I should check? Now that I pulled the oil tank apart (and put it back together) I can see that replacing the pump is not that difficult, its just that the access is tight. If I fill the tank on the motor manually do I run any risk of damaging the motor?Thanks again, this has been most helpful.
  #15
Old October 11th, 2004, 03:19 PM
hello at the remote tank check for 12 volts on the brown wire at the pump with the key on. if 12 volts is not present test the harness between the engine and the pump. test the blue wire at the pump to an enige ground with the key off and the emergency swicth ON. the circuits all use a ground to operate. all the emergency switch is is a toggle switch with one lead to the engine the other spliced into the blue lead going to the oil tank. you can also use jumper wires and run the brown lead to 12v+ and the blue to ground. if the pump runs its fine.somewhere on this site is an excellent trouble shooting chart for the precision blend. do a search for it. good luck and keep posting
  #16
Old October 17th, 2004, 02:57 PM
Rod- an update. Pump runs with 12v directly. The brown has power. The blue did not have a ground at the tank. Unplugged harness at the engine, blue has a ground. That would make me think I need a new harness, yes? The harness also seems very very long and is just doubled over many many times. Is there a reason for this?Thanks.
  #17
Old October 18th, 2004, 04:47 AM
hello the reason is the harness comes in standard lengths and sometimes are just to long. if you tested continuity to ground with the emergency switch up and had it at the engine connector and not at the tank connector I woulds suspect a break in the blue wire in the tank harness. good luck and keep posting
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1984 yamaha 115 alarm? greggg Yamaha & Suzuki Outboards 11 September 5th, 2006 06:56 PM
2000 Yami 200SWS EFI - uncontrollable RPM fluctuations cuonawv Yamaha & Suzuki Outboards 3 April 8th, 2006 06:32 PM
Yamaha 70 HP Alarm vicbear13 Yamaha & Suzuki Outboards 6 August 27th, 2005 09:21 PM
yamaha eng. alarm help puddle pirate Yamaha & Suzuki Outboards 11 January 13th, 2004 05:27 PM
low oil alarm on Yamaha OB 2000Fisherman Yamaha & Suzuki Outboards 0 May 6th, 2003 02:21 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
