  #1
Old September 30th, 2004, 02:40 PM
Osprey Osprey is offline
Default 95 Yamaha 175 Cooling Sys questions
95 Yamaha 175 - Now that I've replaced the impeller, Thermostats and poppet valve. If I put two to three hundred hours per year on the motor, all saltwater, flush after each use and trailer store.How often should impeller, thermos and poppet be cleaned / replaced?Is there anyway to determine if thermos are stuck open other than inspection?Also the overheat warning seemed to switch back and forth between two pitches, one higher than the other. Does the higher pitch indicate she's really getting hot?
  #2
Old September 30th, 2004, 03:04 PM
rodbolt rodbolt is offline
Default Re: 95 Yamaha 175 Cooling Sys questions
hello every 200 hours or once per year is yamahas reccomendation. the alarm tone change idicates either the horn is failing or you have some corroded connections. good luck and keep posting
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1993 140 Cooling System Questions mudd_mickey Johnson & Evinrude Outboards 8 March 20th, 2007 09:33 PM
Freshwater cooling kit install questions billh1963 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 10 January 4th, 2007 07:40 AM
400 Stringer - cooling system questions mattsmall1972 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 21 August 4th, 2006 04:02 PM
1977 Merc(4.5) Cooling water questions groovy.dude Mercury & Mariner Outboards 4 June 10th, 2005 04:26 PM
1987 Johnson cooling questions Bill kubiak Johnson & Evinrude Outboards 1 August 26th, 2004 06:48 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
