hello
yellow is key on power,black is ground, red is fused 12v,green is tach send ,white is kill at the switch and fuel level at the speedo(two seperate cicuits do not hook them together)blue at the switch is choke,blue at the gauge is lights. there is a pigtail of one blue and a double yellow that can be hooked together to have the gauge lights come on with the key. there is also a fuse in the tach harness from the switch to the gauges.
good luck and remember is a simple DC 12v circuit. dont make it complex
