  #1
Old September 25th, 2004, 07:30 PM
Osprey Osprey is offline
Default Yamaha 175 Cooling Sys - RodBolt you can say I told you so!
HelloPurchased 95 Yamaha 175 a few months ago. RodBolt you had encouraged me to deal with the cooling system. But I had "more important" things to get done.Today 15 miles out and heading for 50, overheat alarm goes off. Back to the dock at 1.2 knots with our tails between our legs.Pulled the lower unit, impeller with white internal plastic bushing had spun. Put complete impeller kit in. Pulled thermostats both frozen in open position, looks like for a long period of time. Pulled the poppet valve all gunked up, don't know how it was stilling functioning and this motor had been running great all summer.PS. Picked up two new fuel pumps while I was at it, cheap insurance.One quick question. I have also had some very minor oil leakage from the small drain/weep holes on the lower unit after motor sits on the trailer for a week or so. The oil is dark and quite thick, but don't think its gear oil. After pulling the lower unit, it looks like its coming from the main shaft bushing / seal thats located were the main shaft enters the motor / powerhead. It appears to be retained with a c-clip. Is this any problem to replace and will it likely take care of the oil leak?
  #2
Old September 25th, 2004, 09:57 PM
bigbrownbuku bigbrownbuku is offline
Master Chief Petty Officer
Default Re: Yamaha 175 Cooling Sys - RodBolt you can say I told you so!
thats burnt 2 stroke oil leaking from the gearbox drains. it leeches down the sides of the exhaust during long periods of inactivity.
  #3
Old September 26th, 2004, 05:05 AM
rodbolt rodbolt is offline
hello that was most likly caused by the overcooling. I would imagine you have a lot of carbon in the exhaust now. that is why I tell people you can pay me now or pay me later. but the price of the pump kit is the same whether or not you buy pistons. I hope all is ok. yamahas are fairly tough. the bushing you refer to is a steady bushing used on 25 and 30" shaft motors. it will require periodic replacement. feel it carefully for cracking and for distortion. the corrosion builds between the bushing and the housing and crushs the bushing against the shaft. good luck and keep posting.
  #4
Old October 4th, 2004, 05:26 PM
scottoz scottoz is offline
rodbolt - when I bought my 93 115 yammie it had a good impellor but thermostats had been frozen open for years I think - mechanic put a heat meter on and it was running way too cool - am I best to attempt to clean exhaust/de-coke engine with a spray/somthing else?Thanks mate
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1994 Yamaha 225 SWS 2 stroke-Rodbolt Laram51 Yamaha & Suzuki Outboards 19 February 18th, 2007 07:28 PM
Rodbolt: cooling water temp sensor 2000 yr carb 175 yamaha v-6 mclamown Yamaha & Suzuki Outboards 5 December 8th, 2006 07:54 PM
Rodbolt yamaha charging ? cthru1 Electrics, Electronics and Trolling Motors 1 February 6th, 2006 02:48 AM
Yamaha Oil Buzzer (Round 2) Rodbolt igofishn Yamaha & Suzuki Outboards 8 May 29th, 2005 06:52 PM
Rodbolt ..New 225 yamaha ?? Lloydramdeen Yamaha & Suzuki Outboards 11 January 20th, 2005 01:09 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
