  #1
Old September 10th, 2004, 02:51 PM
mtcamp mtcamp is offline
Default Yamaha 8HP top cylinder runs rough
2004 Yamaha, 8 hp. 2 cycle.I run this motor about 6 to 8 hours at low speed around 1200 rpm. And the longer it runs, the worse it runs. The top cylinder seems to misfire about every 5th or 6th stroke and is most noticeable at idle speeds. Trouble shooting: Tested by the dealer and myself numerous times at about 1500 rpm with engine cold or hot. - When the top cylinder plug wire is removed the motor will run fairly smooth indefinitely on just the lower cylinder. But when the lower cylinder plug wire is removed the top cylinder runs very rough, hits about 5 to 6 times, and dies every time. I can reverse the plug wires on this motor because it fires at the top and bottom of each stroke. This does not change any thing as the top cylinder always runs bad.A local dealer found the same situation with a brand new, out of the box, 2005.Yamaha said that it uses a Siamese” ignition and that’s the way it runs. Sounds like a fish story.
  #2
Old September 21st, 2004, 09:55 PM
Grant S Grant S is offline
Default Re: Yamaha 8HP top cylinder runs rough
If it is still under guarantee it is Yamaha's problem. I have an older model of these and they are usually great motors, look at how few postings there are about them.Have you tried swapping the plug as well as the leads?(had to ask).Given that you seem to have eliminated ignition problems on that cylinder , it must be something else, inlet or exhaust tract problems/blockages perhaps. Did the local dealer say what the problem was , on the one out of the box? 2005?-are you a time traveller?A siamese ignition just means that they are paired and perform together, like you stated.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha Four-stroke 225 runs rough at idle topperbt Yamaha & Suzuki Outboards 12 June 9th, 2009 08:10 PM
1985 DT75 Suzuki runs real rough at low RPMs/Idle & in gear. #2 cylinder low TimDollar Yamaha & Suzuki Outboards 0 February 8th, 2006 06:51 PM
92 Yamaha 40 runs rough, misses PeteB88 Yamaha & Suzuki Outboards 9 September 9th, 2005 03:33 PM
Yamaha 25 runs Rough stauter99 Yamaha & Suzuki Outboards 3 October 6th, 2004 11:11 PM
yamaha 50hp runs real rough then dies willie77 Yamaha & Suzuki Outboards 2 April 27th, 2004 06:36 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
