I just got a boat with twin yamaha 200's (salt water series). I am a newbie.<br />One sounds just fine when I move it up or down.The other sounds bad (screeches)and the engine needs to be moved by hand to get it going. I have not moved it since this happened. There is also an oily substance on one of the rods that pushes the engine up. I imagine that it is hyraulic fluid.<br />Does it just need some fluid or is the hydraulic motor shot ? Where do I put the oil ? I don't have the manuels.Should there by some oil on the rod or is it leaking ? Is this something I can do myself or should a mechanic look at it ?
