  #1
Old August 10th, 2004, 11:33 PM
Millmaker Millmaker is offline
Default Yamaha 225, ignition problem?
Hello!Started up my 91 yamaha 225 BETO(thats the model type in Norway), runs great on idle for a while. Did start the engine on shore. When i throttle up works fine to,but after a while it almost died when throttle,but came alright again. same problem again and again. runs good on idle.Suddenly a flame came out of the lower carb,happened twice.Could it be ignition problems or what?The motor has a TPS(throttle pos. sender?), could it be something with that one?Any help would make me happy!
  #2
Old August 11th, 2004, 02:09 AM
vidar vidar is offline
Default Re: Yamaha 225, ignition problem?
i think you have a fuel related problem...check that your fuel pump workes right..try to squeese the fuelbulb on the line when you try to to apply throttle..
  #3
Old August 11th, 2004, 03:24 AM
Ok, maybe youre right. See you too are from Norway, good to see more of us!I havent got any bulb on it, got a separate el. fuel pump though. But seems to get too much fuel if that one is running all the time, im not sure.Is there any easy way to check the fuel pumps on my motor? It also have a prime starter, looks like a fuel pump, but with 2 solenoids on it.
  #4
Old August 11th, 2004, 08:22 AM
i bypassed the puls fuelpump on motor and just used the electric pump....take off fuelline on carb t see that fuel reach carb w some pressure...then drain carbs to see that you got clean fuel...then check timing w stroobelight...if way off you can have shered flywheel pin...the tps contols timing point (not advansing) w throttling up but this only gives poor performance not unwilling to accelrate froooom idle... is this in gear or in neutral??
  #5
Old August 11th, 2004, 10:25 AM
This happenes in gear and neutral. but not all the time,it can run good for a while too.Do you have any idea what i should see if i use a strobelight to check the timing? Any numbers coming up or what? I have one of these strobes,but i am not sure what to read. And if it is wrong, then what do i do?Thx!
  #6
Old August 11th, 2004, 05:27 PM
rodbolt rodbolt is offline
hello if you have not done it then replace all the fuel pump diaprhams. clean the carbs they are most likly due. the flame coming from a carb on a two stroke indicates that the fuel mix in the crankcase is lean and it may indicate a bad reed set, the fuel is only supposed to go in one direction. thats why two strokes dont have to have flame arrestors. the reed is supposed to stop it. the TPS on that motor failed sometimes due to weak tension on the wiper arm. I dont have the specs for the 91 model in front of me but warm idle should be somewhere about 6*ATDC and wot abot 22*BTDC. all the timing in between is computer controlled. the TPS is rather pricy but the backfire is almost always due to a lean condition. good luck and keep posting
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
95 Yamaha 40 hp ignition problem gbatts2 Yamaha & Suzuki Outboards 4 April 6th, 2007 08:43 PM
87 Yamaha 90 ignition wires? Dank Yamaha & Suzuki Outboards 2 March 6th, 2007 11:28 PM
1985 Yamaha 150 ignition problem kerrymc1 Yamaha & Suzuki Outboards 5 October 27th, 2006 05:09 PM
Yamaha ignition... mike622 Yamaha & Suzuki Outboards 4 June 7th, 2004 07:17 PM
2001 yamaha 25hp 4 stroke ignition problem michaelgill1822 Yamaha & Suzuki Outboards 0 August 24th, 2003 08:46 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
