  #1
Old July 29th, 2004, 08:18 AM
SliderM72 SliderM72 is offline
Default Warning Buzzer 1988 115 Yamaha
Hello, My motor runs great, but if I push it past 4200 rpm's for more than 5 minutes, the warning buzzer comes on and powers down. I then wait about 10 minutes and am able to restart with no buzzer. My Seloc Manual says that it is either an overheating or an oil related issue. The water coming out of the telltale isn't hot when this happens, but I did notice that the mid section was pretty hot. I also noticed that I don't seem to be using as much oil as I normally do. I have recently (last 3 weeks)went through about 65-70 gallons of gas, but have only seen the oil in my remote tank go down by about a third. AS I'm writing this I realize it sounds like an oil starvation problem, any suggestions? Thanks.
  #2
Old July 29th, 2004, 12:00 PM
rodbolt rodbolt is offline
Default Re: Warning Buzzer 1988 115 Yamaha
do you have the yamaha tach? if so what visual indicator are you getting. if you catch it as soon as the alarm goes off and look and see if the engine oil tank is low. also use a temp stick or gun to test the head temps. when was the last cooling system service? good luck and keep posting you also described a classic remote oil filter restriction. when was the last remote oil tank filter service?
  #3
Old July 29th, 2004, 07:10 PM
Thanks Rodbolt. No I don't have a yamaha tach, couldn't afford a new one, relaced with a teleflex. Water pump and impeller wre replaced 3 months ago. I haven't had a oil filter service, but I will check that and let you know. Thanks again.
  #4
Old August 2nd, 2007, 08:04 PM
richardr richardr is offline
Smile Re: Warning Buzzer 1988 115 Yamaha
i have the problen now
is it a big deal to take off and replease the heads ????
i have a 1996 200
the engine is great
also i have not used it that much and i feel that the carbs should be cleaned is the a big deal.
richard r:
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha Warning Buzzer -- Overheating? dharris02 Yamaha & Suzuki Outboards 9 November 4th, 2008 07:45 PM
1988 150 HP Evinrude Buzzer??? Warning Alarm??? jrcastro2000 Johnson & Evinrude Outboards 2 August 18th, 2006 10:07 PM
Yamaha Warning Buzzer seamanship Non-Repair Outboard Discussions 7 September 6th, 2005 02:00 PM
Yamaha Warning Buzzer -- Overheating? dharris02 Yamaha & Suzuki Outboards 0 May 27th, 2003 12:26 PM
85 Yamaha 90 HP Warning Buzzer ? Help !? starcraft Yamaha & Suzuki Outboards 4 May 19th, 2002 05:02 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
