Re: yamaha waterpump replacement
I would also suspect the poppet valve and try replacing it prior to haul out. The poppet valve allows a little water circulation when the engine is cold so that the impellor doesnt get chewed. If it is closed all the way then this would explain why the pee hole is not strong. As a general rule water pumps should be replaced every 2 years! Dont skimp and do just an impellor, rather spend the extra time and a few extra bucks to get the whole kit (approx $50-60). The kit replaces all the gaskets, water tube seal, impellor and impellor cup. Would also be a great time to pressure and vacuum test the lower unit. If you have a bad lower unit seal under the water pump you already have the lower off and the pump off since this seal is under the water pump assembly. The other seal is on the prop shaft. You should have the prop removed and grease that spline also. with new thermostats, poppet valves, water pump kit, pressure/vacuum testing the lower and new lower oil you are bullet proof in the cooling and lower unit area! all that would be left is fuel filters, decarb, plugs, and timing/adjustment!!!
