hello
the 76* motors had some uniqe features for acceleration. the fuel pumps need to be replaced about every 3 years,they get old and tired like me. test the engine compression then all the spark plug caps. yamaha had some stator issues back then so do a hot running charge coil output test to insure proper CDI output voltage.the TPS also sends throttle valve position as well as motion to the computer. on rapid throttle opening the computer will change timomg as well as add fuel through the six valves on the carbs. if #6 fuel bowl is not full it will suck all the fuel from the bowl and bog. that is why those engines have to have perfect fuel pumps.
you may wish to find a tech that is familiar with your engines.
good luck and keep posting
