Re: starter problem
Just in case others out there are searching the history for help on starters...<br /><br />I have a 2000 200hp OX66 efi:<br />I thought I had starter problems as well. The first signs of trouble was the starter spinned, but the "bendix" wouldn't "pop-up". Switched batteries, and voila, it worked - an hour later we were on the water. <br /><br />The next time to take it out, 2 months later, same problem! Except the more I tried it, the starter wouldn't turn over at all. Switched batteries (both I knew were fully charged!), still nothing. I thought it was the starter, so I took it off, and brought it to an expensive shop to test it. They bumped it with a battery, and viola, the bendix popped up - nothing wrong with the starter! I thought then I had a bad solenoid, or something else... <br /><br />I talked to a knowledgable, local boat mechanic, and he suggested I "tighten the wingnuts on the battery." Would you believe that's all it took?? I tightened the wingnuts probably a half a turn with pliers, and she started right up! <br /><br />Jeez... live and learn (every outing!)<br /><br />Mike, Eagle Point, Tx
