  #1
Old July 11th, 2004, 06:34 AM
andymach andymach is offline
Default Are Yamaha gear box rattles normal?
My last post refers to this. Sorry for posting again but I really need some info on this.My boat has just been re-engined with a new, out of the crate Yamaha F-40 4 -stroke. When run in gear on the muffs & hose there is a rattle from the gear box. The sound comes and goes. The Yamaha dealer initially thought it was a faulty gear box. He was going to order a new lower unit until he started a Yam F100 4-stroke with 10 hrs on it. It made the same noise on the muffs. A 10 hr F115 was significantly quieter but the noise was still there. The noise is there at idle revs and higher revs, up to 2.5 k was tried. It doesn't get any louder as the revs increase and follows the same pattern of stoping and starting. Is this to be expected, when in gear, out of the water, as there is no load on the prop, or should the gears be silent as they are in bearing races and bathed in oil?It would be great if an experienced Yamaha tech could answer this. Thanks to those who have already replied.
  #2
Old July 11th, 2004, 01:07 PM
jrod8v92ti jrod8v92ti is offline
Default Re: Are Yamaha gear box rattles normal?
not bad most people dont think about water resistance on prop general rule of thumb your lower unit is good if 1. backlash in fwd and reverse are in accordance with manufacturers specifications.2. unit passes pressure and/or vac test3. operates as designed.(shifts correctly)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha OX66 EFI vibrates and rattles AQUADJ Yamaha & Suzuki Outboards 10 October 11th, 2006 07:59 AM
1995 150 's one rattles when run slower... Fl_Richard Johnson & Evinrude Outboards 0 June 3rd, 2006 06:08 PM
Deer; Calls Scents Rattles Etc. neumanns Dockside Chat 23 November 10th, 2003 01:58 PM
Yamaha 3.0 I/O dies when put in gear. whiteboy71759 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 13 April 17th, 2003 07:41 PM
71 Merc 650 Rattles at idle & part throttle xbuellx Mercury & Mariner Outboards 2 August 6th, 2001 06:53 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
