1999 Johnson 90 Lower Unit Oil?
ddoty
I just bougght a Glastron with a 1999 model year Johnson 90hp outboard. I wanted to change the lube in the lower unit, but I am unsure what it takes. Any help? I imagine you just fill it until the lube starts seeping back out of the fill hole? Thanks in advance. Service manual is the next purchace.
roscoe
Re: 1999 Johnson 90 Lower Unit Oil?
Put lube hose/tube into the bottom/drain hole, fill till it comes out the top/vent hole.<br /><br />Don't have a book on that motor, but it probably holds about 26-32 ounces of lube.
dajohnson53
If you're asking what type of lube - buy any marine grade lower unit gear oil, generally labeled 80W90 or similar. It's available in any boat shop or any place lube or boating supplies are sold, including a lot of gas stations, auto parts, hardware, and big box (Wal Mart, Target, Fred Meyer, etc) stores. Put the same thought/money into the purchase as you would the lube in your car. In other words, it's no more technical than any other lube decision - if you're a name brand or synthetic kind of guy, do that. If you're happy with generics, do that. I tend to buy Valvoline because an auto parts store near to where I live sells it. I've used el-cheapo generics many times without problems. If I happen to be in the boat shop (rarely - it's waaay across town), I go ahead and buy the OEM brand. it is a little more expensive, but not a significant factor (say $7-8 for the job rather than $5-6). <br /><br />If you're asking how much - buy a quart bottle or at least two squeeze tubes. Whatever you don't use, you'll use next time. You'll change it again, at a minimum, before putting it up for winter storage. Since it's a new-to-you engine, you'll probably want to check the lube after a couple times running it just to see it's condition. Look for an attachment (for either the quart bottle or squeeze tube) which will make the job easier.
Solittle
Make sure that you get new gaskets for the fill/drain plugs.
ddoty
Thanks for the replies guys. I appreciate it. So I do just fill it until it starts running out of the fill hole then? I am an auto tech, but pretty new to boats. Thanks again!
dajohnson53
Originally posted by Dave D:<br /> Thanks for the replies guys. I appreciate it. So I do just fill it until it starts running out of the fill hole then? I am an auto tech, but pretty new to boats. Thanks again!
The bottom hole is called the fill hole, the top hole is called the vent hole. You fill from the fill (bottom) hole until it runs out the vent (top) hole.
