  #1
Old June 22nd, 2004, 07:16 PM
wjkane wjkane is offline
Default Yamaha 704 Control Power Trim Switch Not Working Correctly
I have a 2000 Yamaha 200 Saltwater Series II with the Yamaha 704 Remote Oontrol Box. The Power Trim switch started giving me trouble intermittanly when trying to put the trim in the up position and now it hardly ever works. The switch gives me no problems when I try to put the trim down. The trim switch on the outboard itself, works just fine bot up and down. I am thinking that my contact in the switch must be bad? Is this something I can take apart and replace the switch without too much trouble? How do you replace/fix the switch in the remote control handle.
  #2
Old June 22nd, 2004, 08:29 PM
lysis217 lysis217 is offline
Default Re: Yamaha 704 Control Power Trim Switch Not Working Correctly
had the same thing happen to my '93 Yamaha. its the switch on the throttle, notorious for corrosion. take it out by taking off the plastic cover on the throttle stick, carefully pry open the switch with a small screwdriver, and clean the little seesawing plate, and the contacts on either side.
  #3
Old July 15th, 2004, 08:09 PM
Lysis217, Hey thanks buddy. I will give this a try. I have been busy and I'm late in checking this response, but I appreciate it. Bill
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Trim switch yamaha 703 control v12mac Yamaha & Suzuki Outboards 2 November 18th, 2006 08:01 PM
EVENRUDE 225 vro trim meter not working correctly jurgenscraft Johnson & Evinrude Outboards 2 May 6th, 2006 11:34 AM
bayliner capri power trim not working correctly timcawley Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 August 18th, 2003 07:37 PM
bayliner capri power trim not working correctly timcawley Johnson & Evinrude Outboards 1 August 18th, 2003 07:13 PM
YAMAHA can't trim down from control switch and its not the switch. letsbarbq Yamaha & Suzuki Outboards 4 August 4th, 2002 11:05 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
