Coming in yesterday, my 200 HP Yamaha (1990)<br />prop seem to stop spinning. Engine remained at high RPM but no forward motion. I thought I hit bottom (was in deep water) at first. I started the motor and began going forward at slow speed and was able to make it back to the dock. When I tried to go at a faster speed, the prop seem to not spin or slip on the spindle. However the RPMs went up when I increased the gas. It acted almost like a burned clutch!!!<br />Before I pull the boat and take it to a dealer for repair, do you have any sugestions as to what it may be? I listen for noise in the lower housing, but it seemed to be running normal. I checked for any damage on the lower housing and there was none.
