  #1
Old June 15th, 2004, 08:16 PM
dflorea dflorea is offline
Default 1999 Yamaha 200 EFI Oil leak
Im in the process of purcahasing a used boat with twin 200 0X66 out boards. I had the boat surveyed. The surveyor told me there was a puddle of oil in the bottom pan of the port engine. What would/could cause this? tilting of the engine and leakage from the plastic oil bottle, or something worse. Any info would be appreciated .
  #2
Old June 16th, 2004, 05:19 AM
Ray Neudecker Ray Neudecker is offline
Default Re: 1999 Yamaha 200 EFI Oil leak
An incorrectly installed tank sensor or a problem with the sensor it self are the most common causes. If the cap is not installed correctly oil will leak when the engine is tilted. Sensor problem may cause the tank to overfill.
  #3
Old June 16th, 2004, 05:15 PM
rodbolt rodbolt is offline
hello and sometimes the sensor just leaks where it passes through the tank.. if you remove it pay attention to the screen instalation. if done wrong it will cause a problem. also make sure the screel seal comes out of the tank. always use a new seal. if you dont retrive the old one it can cause a problem. good luck and keep posting
  #4
Old June 16th, 2004, 07:26 PM
Thanks guts Ill keep in touch.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1999 Johnson 90 oil leak ddoty Johnson & Evinrude Outboards 0 June 23rd, 2005 11:06 AM
1999 yamaha 115 randyroeder Yamaha & Suzuki Outboards 2 April 15th, 2005 01:22 PM
1999 115 hp yamaha leesurenail Yamaha & Suzuki Outboards 2 October 27th, 2004 12:10 AM
1999 Mercruiser 3.0 Timing Cover Oil Leak cjcrotty Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 10 June 22nd, 2004 07:23 AM
Oil Leak from propeller area on 1999 90hp Johnson chuckdaddy673 Johnson & Evinrude Outboards 2 January 20th, 2004 02:33 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
