Re: Propeller shaft bent
It is pressed-in, or at least, the bearings are,and require a puller tool. A good puller is available at most auto stores, but the REAL problem comes when trying to press it back in.But the same machine shop that <br />trues-up your shaft will have the required equipment to remove it,and press the bearings back in when done.<br />If it were mine, I'd take the entire lower unit to the shop, and let them do the whole job,if you don't have all those tools (like a press,puller,pressure tester,and all)<br />Make sure the unit is pressure and vac*** tested after the job is complete,to ensure there are no leaks.<br />If you would rather not go through the hastle, he can exchange it for a rebuilt unit,but that is VERY expensive. If I were him, I'd go the machine shop route.<br /><br /><br /><br />------------------<br />I'm no expert, but I DID sleep at a Holiday Inn last night!
