  #1
Old June 5th, 2004, 04:03 PM
gump218 gump218 is offline
Default 1995 Yamaha T9.9 Electric start Water Circ
Just purchased a used sailboat with the Yamaha T9.9... 4 Stroke. Motor starts fine...spits a little water then nothing. Seems to be dry; then starts gurgling and finally spitting a steady stream; then stops spitting again...Cyclic.. I rebuilt the water pump. New impeller, etc.... Everything is in solid. Still the same sympton... I can disconnect hoses from the power head and get no flow to the pee-hole...Any ideas/suggestions would be appreciated... Owner said the motor was very low hours.... Looks like new...
  #2
Old July 19th, 2004, 05:19 PM
Default Re: 1995 Yamaha T9.9 Electric start Water Circ
Solved the problem today.... Removed the Exhaust cover and inner exhaust plate. Found several orifices clogged with caked salt and some corrosion. Removed the cylinder head and found the same problem throughout the cooling water path.... Used hot water and a dental pick to remove most of the buildup. Two of the tubes that run adjacent to the spark plugs were so caked that I had to "drill" out the salt...Started with small bits and worked my way up until I got clear passage (checked by blowing through the tube with a rubber hose). Reinstalled everything and tried the flushing attachment. The motor spews water now!I had rebuilt the water pump and checked the thermostat. The local Yamaha dealer told me to hang the engine up and trade for a "New" motor because after 10 years this engine had to be shot... Major corrosion and salt build-up. He offered me $600 for a trade-in. Had nothing to lose so took the plunge at disassembly and repair. I learned a BUNCH and will probably add the tear-down to a periodic maintenance cycle so I don't have to deal with the problem again. I will continue to flush the motor after each use...I love it when a plan comes together!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1995-97 Mercury 25 hp electric start Greyelk05 Mercury & Mariner Outboards 3 November 15th, 2005 09:03 AM
Yamaha 25hp Electric Start Tomxx7 Non-Repair Outboard Discussions 1 May 28th, 2005 12:01 PM
Yamaha 40, adding electric start? mallardjusted Yamaha & Suzuki Outboards 3 March 5th, 2005 06:22 AM
Yamaha 55 electric start outboard JOHN O'LEARY Non-Repair Outboard Discussions 1 October 13th, 2003 03:34 PM
Yamaha Electric Start Conversion Riverjet Yamaha & Suzuki Outboards 0 May 16th, 2001 06:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
