  #1
Old May 27th, 2004, 10:21 AM
joedawg joedawg is offline
Default Yamaha F50 '02 w/ "dead spot"
I have a '02 Yamaha 50 four stroke that has two problems that might be related... First problem is that it has a "dead spot" on the throttle... About halfway forward, just before enough power to plane out, the motor, when agressively moving the throttle forward, has a dead spot that stalls the engine... If proceeding at a gradaul pace thru this "dead spot" then just a slight hesitation... Also, the engine does not like to start when cold... Need to keep pumping the primer bulb to keep a good flow of gas into the engine... Any suggestions out there?
  #2
Old May 27th, 2004, 02:12 PM
Ray Neudecker Ray Neudecker is offline
Default Re: Yamaha F50 '02 w/ "dead spot"
Apparent fuel restriction, I would suspect fuel pump or carb problem. Trying priming with the cowling off and see if fuel leaks out of the carbs. This would indicate a sticking needle valve.
  #3
Old July 6th, 2004, 09:50 AM
I did prime the motor with cowling off and there was not any leakage... Using the boat the past few times, I have been able to start it with now with no problem... I must lift the idle throttle to full and she starts on sometimes the first, but almost always on the second turn of the key.... I am still having the dead spot issue when I move the regular throttle forward in a manner other than slow... I have alwasy been hauling other trailers when heading up and back from the lake so its been hard to get the boat home... I might just have to "bit the bullet" and take a quick trip to get it in to a shop but am wondering if there is one more thing to try...
  #4
Old July 6th, 2004, 10:08 AM
rodbolt rodbolt is offline
hello a thourough inspection of the linkage and then the accelerator enrinchment circuits. your engine is also equipped with prime start. DO NOT use the warm up lever to start. if it wont start with the lever down its broke. get it fixed. the carbs are rather touchy on the 50 and without a manometer almost impossible to set up correctly. good luck and keep posting
  #5
Old July 9th, 2004, 07:45 PM
rowbards rowbards is offline
sounds like a pilot jet adj. to me...I've had a few of these with the f/t50. some i've found to be completely closed...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
motor has "dead spot" in throttle when accelerating johnwick Mercury & Mariner Outboards 2 December 9th, 2005 03:09 PM
1989 88 Hp Johnson manual lift assist "dead" Old No 7 Johnson & Evinrude Outboards 4 July 1st, 2005 08:07 AM
Father John "the child molester" Geoghan Dead Ralph 123 Dockside Chat 60 September 4th, 2003 10:04 AM
Alarm and "Flat Spot" Trouble with my first Used Boat oldsearay Mercury & Mariner Outboards 3 August 6th, 2003 06:10 AM
NAME YOUR MOST ENJOYABLE AND RELAXING PLACE " YOU KNOW THE SPOT" ARRIVVEEINPOLO Dockside Chat 22 March 1st, 2002 10:48 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
