Re: 1990 yamaha oil injection problem!
snookit,<br /><br />First things first, do you ever get the yellow light? Or even have the three lights for oil, green, yellow and red. I assume the red light is working and that is how you know you are out of oil. <br /><br />If you are not getting the yellow light, but the red and green work, you need to check the connectors from the sub base tank to the motor. You are not getting power to the sub base tank(the remote tank)<br /><br />Do you hear the pump run when you turn the key to run before starting? you should as long as the reservoir on the motor is not full. <br /><br />If you hear the pump run, but nothing is comming out, check the filter at the bottom of your subbase tank first, see if it is clogged. If you don't hear the pump run, you have an electrical problem in the connectors or the pump is bad.
