HELLO
its a motor
SUCK,SQUEEZE,BANG AND BLOW,
all the high tech stuff does is make it more efficient.
drain a sample from the vapor seperator. test the low pressure fuel pumps for leaking diaphrams. do you see a lot of gas spots in the water while it idles?
have you cleaned the 02 sensor lately? how about changing the plugs? lots of basics on the motor that get overlooked.
dont let the high tech intimidate you. it still has the basic fuel compression spark and exhaust cycles. the high tech on these motors rarely fails. usually if a high tech part fails the engine disentergrates or just wont run.
good luck and keep posting
