  #1
Old April 26th, 2004, 04:49 PM
willie77 willie77 is offline
Default yamaha 50hp runs real rough then dies
i have a 50hp yamaha motor, made in 2001. i left for iraq in 2003, didn't winterize it at all(i live in texas i didnt think it was necassary). now the motor starts after some coaxing, runs really rough, when i throttle down on it it sounds like the motor is choking out and dies. it also spits fuel out the exhaust. it does what i would call a hiccup, if motors could actually hiccup, and sounds like its sucking air but have no idea from where, just sounds like air being drawn in. i replaced the plugs and put fresh fuel in it before i had ever tried to start it. now i have tried the engine stabalizer aditive for the fuel and cleaned the carbs. it ran probably at 75% for one trip to the lake. i thought i had fixed it but the next weekend it was acting up again. any help or suggestions would be greatly appreiciated.
  #2
Old April 26th, 2004, 05:45 PM
rastoga rastoga is offline
Default Re: yamaha 50hp runs real rough then dies
If you haven't already done this...Your carbs probably need to be removed from the engine, taken apart, and cleaned. There are lots of little holes, floats, and jets that easily get gummed up after sitting a while. Cleaning them will help restore your motor's performance. In your situation I would replace all the carb gaskets and rubber bits to help rule out any air leaks. Carb overhauling is easy to do on your motor if you use a repair manual. Also clean/replace your fuel filter, inspect fuel lines, and clean out your gas tank.Try these steps and see if you still have the symptoms you mentioned.Good luck and welcome back from Iraq.
  #3
Old April 27th, 2004, 06:36 AM
jim dozier jim dozier is offline
Do what rastoga suggests. The "hiccup" is what 2-strokes do when they are running lean which is consistent with a need for a carb rebuild/cleaning (gum or crud in the internal orifices). As rastoga said you cannot clean a carb properly without taking it off and dismantling it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mercury 150 runs rough and dies eric1111 Mercury & Mariner Outboards 9 August 20th, 2006 07:22 PM
1968 35 hp merc wont pee and runs real rough dafooge Mercury & Mariner Outboards 3 July 16th, 2006 02:07 PM
1985 DT75 Suzuki runs real rough at low RPMs/Idle & in gear. #2 cylinder low TimDollar Yamaha & Suzuki Outboards 0 February 8th, 2006 06:51 PM
92 Yamaha 40 runs rough, misses PeteB88 Yamaha & Suzuki Outboards 9 September 9th, 2005 03:33 PM
Yamaha 25 runs Rough stauter99 Yamaha & Suzuki Outboards 3 October 6th, 2004 11:11 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
