water pump repair
Dead Eye
2002 225 efi 2 stroke<br /> I want to replace the water pump on my motor. Do I need the whole kit or could i just replace the impellar and gaskets. What parts do i need to get it done?<br /> Thanks, Dead Eye
Laddies
Banned
Re: water pump repair
In most cases the impeller kit, imp,plate and gaskets will work, but in some cases it will also take a housing or even a base. You almost have to open it and look to be sure or you have all the bases covered if you buy a w/pump kit
