Oil and lubing questions?
bensdsu
I am completely oblivious to boats. I just bought a older (71) seaswirl with a two stroke 65 HP Mercury Outboard. I know the motor is newer than the boat but it has no stickers or any info on what year it is. How can I find out the year of the Motor? Even more important what should I do to the motor before I launch the boat? Do I need to change any oils or lube any gears, How do I do this, because the boat has not been in the water for almost two years. Any info is a big help!
dajohnson53
Re: Oil and lubing questions?
If you can find a serial number on the engine, there are websites that can guide you to the year. <br /><br />You should get rid of all the old fuel and start with fresh gasoline mixed at a ratio of 50:1 with tcw3 2 stroke oil.<br /><br />I would also drain and replace the lower unit lube and replace the fill and vent gaskets (washers) with new ones made for that engine - the proper gasket/washers does really make a difference in preventing water intrusion. If you don't know how to do this, there's lots of threads on that subject if you do a search. Or get an owner's or shop manual and it should tell you how to do it. Then, assuming it runs, after an hour or so of running, I'd drain it again and see if there is water intrusion. If so, that would be an issue to work on, although you can run it as long as you replace the contaminated oil frequently and don't let it freeze with moisture in the lower unit.<br /><br />If it starts, you want to make sure the "telltale" is streaming at all rpms indicating a working water pump. The water pump impeller is something you might want to replace on a preventative maintenance basis if you have any suspicion it's old. You'd definitely want to do water pump service if you think the water stream out of the tell tale is weak or sporadic. <br /><br />If it idles and runs fine, you're probably good to go. If not, you'd probably have to get into troubleshooting fuel system, carb., spark and compression just to see where you stand. If that's the case, there's many experts on this forum who can guide you (I'm not one of them!).
05GlastronSX
to find out the year of your motor you first need to locate the serial number on the engine. it is an 8 digit code of letters and numbers. once you find that post it back on here and we will do the rest. What you should do to the motor is check everything over. Buy some muffs and make sure the engine runs. Change the plugs, get some fresh gas and mix it with a good oil at a 50:1 ratio(assuming your motor is not oil injected, if it is this does not apply) Also, before you launch, change the water pump impellor and gear case oil while you are down there. If you are going to do this, i highly suggest buying a service manual for your engine. This has detailed pictures of the procedures and step by step processes for doing everything.
05GlastronSX
sorry for the similar reply D. You beat me to it... :D
