  #1
Old March 27th, 2004, 05:15 PM
BugTosser BugTosser is offline
Default yamaha 703 control
Hello again.I have a question about the 703 control.My control has the key slot then just below the key slot there is a lever and then below the lever is the kill button for the safty lanyard.I do not have the levers on the handle for the tilt.What is that lever between the key and kill button do. Every time I push it up I hear a click, and the click is comming from the solenoid that is hooked onto the lower carb.Is it the choke ?And if it is the choke It is not openning my valves(butterfly) in the carbs. Also is it suppose to click where the solenoid is or is that a sign of a bad solenoid?thanks
  #2
Old March 28th, 2004, 01:32 AM
lakensea lakensea is offline
Default Re: yamaha 703 control
It is the choke and it should be closing the butterflys, not opening.
  #3
Old March 28th, 2004, 05:17 AM
rodbolt rodbolt is offline
depending on model. if your engine has a choke butterfly then they will close. the chokes on most 2 strokes do not alter the throttle butterfly settings. remember If you have an actual choke the carbs will have two plates or butterflies. one for choke which just forces a rich fuel mix for cold starts and throttle butterflies which control or "throttle" air and thus fuel into the engine. good luck and keep posting
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 703 control box downhilldai Yamaha & Suzuki Outboards 4 May 22nd, 2006 03:53 PM
control box for Yamaha 9.9 hastingsml Yamaha & Suzuki Outboards 1 May 10th, 2006 08:54 PM
what yamaha control box ??? defcondaze Yamaha & Suzuki Outboards 5 September 24th, 2005 08:22 AM
Yamaha control box and OMC yrag Yamaha & Suzuki Outboards 1 July 14th, 2002 09:42 PM
Yamaha 703 Control lesterthedog@go.com Yamaha & Suzuki Outboards 2 May 21st, 2002 05:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
