  #1
Old March 27th, 2004, 12:02 PM
bonitoman bonitoman is offline
Default Rodbolt , What is the deal with my yamaha head gasket
My 92 130 has 10 hours on it. I noticed the head leaking water. Still great compression. I removed the aftermarket gaskets and spent quite a bit more for yamaha stock gaskets. The new gaskets were impregnated with that shiny stuff. Usually I put the omc brown gue sealer on gaskets.I did not put anything on these yamaha gaskets. These yamaha gaskets still leak. They were torqued to 22 foot lbs. Am I suppose to put anything on these gaskets or the head itself for yamaha. The heads are straight and have been machined. I am in need of some help. Thanks Rodbolt
  #2
Old March 28th, 2004, 05:28 AM
rodbolt rodbolt is offline
Default Re: Rodbolt , What is the deal with my yamaha head gasket
helo I usually use OMC gasket sealer or perfect seal. if your heads are flat and no visible machine marks then look carefully at the block surfaces. if the aluminium around the cyl liner is gone it will never seal. I have also seen some engines actually corrode a hole into the crankcase area at the v. if you suspect a leak the use shop air at 90 psi and apply air and listen for anyleakage into the cooling system. to do that you will need to make a metal tool to hold the flywheel. I made one that fits in place of the lifting strap. do not try to hold it with a breaker bar. when it spins it will come around and whack your head . I usually submerge the gearcase and use duct tape to seal the exhaust ports. if it does not blow bubbles it may not be a cyl head gasket leak. . have you taken a fine flat file and checked to see if the block deck is true? have you carefully inspected the exhaust divider plate for pinhoiles? when you did the overhaul did you remove the divider plate or shotcut the procedure ? water can enter the cyl from the intake side, the ex ports as well as a leaking head gasket. good luck and keep posting
  #3
Old March 28th, 2004, 06:46 AM
I am going to pull the heads again and coat the head gasket and water jacket with omc gasket sealer just like I have done on omc engines. I will retorque to 22 foot lbs and test today thanks. I did not put anything on the gaskets yesterday.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1975 6 hp head gasket replacement -dry gasket? BF Johnson & Evinrude Outboards 11 July 3rd, 2007 01:46 PM
Yamaha 115 ETLK head gasket? rifleman_maynard Yamaha & Suzuki Outboards 5 October 28th, 2006 05:43 PM
Head Gasket Replacement 130 HP Yamaha SJ Striper Yamaha & Suzuki Outboards 3 September 25th, 2003 11:02 AM
blown head gasket 130 hp yamaha the mailman Yamaha & Suzuki Outboards 1 June 10th, 2003 11:25 AM
salt deposits on cylinder head gasket & water cover gasket mmas261 Yamaha & Suzuki Outboards 3 April 8th, 2003 12:10 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
