using your power tilt lift your motor to it highest point. Then go and locate the manual release valve. turning the manual release valve clockwise will all the motor to drop gently. off course do this on dry land.
The realease valve can normally be found on the right hand side when looking from behind the boat. It is on the powertilt bracket. You will need a good screwdriver for its adjustment. Go to your local dealer and see if you can get a photo copy of the air bleed procedure. it is very easy and will show you where to top the oil up from. "Do Not Use normal Powersteering fluid)
