98 60hp mariner bigfoot
starcraft98
Why can't I shutoff my motor? Starts just fine,but will not shutoff with the key or the emergency kill switch .I first thought I needed a new ignition switch,but that did'nt help the problem.Please help.
studlymandingo
Re: 98 60hp mariner bigfoot
Welcome to iboats.<br /><br />Do you have a manual? You will need to trace the wiring back through the harness, sounds like a bad ground or loose connection.
Silvertip
Disconnect the large control harness connector. Check and clean the terminals and then reconnect it.
