Re: ALARM
Sleepinin, does your manual have a procedure to test warning module? Over the weekend I checked the sending unit on motor block,by removing it from the engine block which would open the circuit if switch was stuck on.Again engine is off and cold but alarm horn is on.Then I disconected the switch where it connects to wire harness,and grounded tan/blue wire from harness to engine block. At this point horn tone changed.When I removed the wire from block,horn went silent. so I plugged in the switch and grounded it. NO alarm. With switch out of block but still grounded I applied heat to sensor and alarm sounded. all is good. But horn would not stop. I disconnected switch from harness again. Horn stayed on. So I grounded wire again and when it was removed from ground, alarm horn stopped.Ran the boat on sunday alarm came on after about half an hour.Checked voltage with meter and it was very stable.Regulater seemes good. Any thoughts???
