  #1
Old March 14th, 2004, 08:37 AM
arboatdr arboatdr is offline
Default 4 stroke yamaha drive shaft stuck in crank
I'm trying to put an impeller in a 4 stroke yamaha 100hp. The drive shaft is stuck in the crank. Have changed many impellers and know for sure all the bolts are out. The lower unit will not come off. Tried to pull the powerhead and it wouldn't budge either. Any ideas on how to get it unstuck without doing further damage? I'm sure the splines have made a lip in the crank and/or just siezed up. I've used prybars, had the powerhead supported on hoist overnight to see if it would pop loose, tried rotating the flywheel in both directions while pulling on the foot. I'd leave it alone but it overheats at high rpm and the customer has never serviced the impeller. I'm afraid I need to get serious with it now and cut the foot off so I can remove the powerhead and get some heat to the crank and shaft.
  #2
Old March 14th, 2004, 10:19 AM
rodbolt rodbolt is offline
Default Re: 4 stroke yamaha drive shaft stuck in crank
hello well now its time to tell the customer about all that miss maint is gonna cost him an engine. odds are the crank is bad now as well. boy he saved mucho dinero by not servicing his motor. the problem is the shaft splines also drive the oil pump. I have had some that we cut a hole in the exhaust housing then cut the shaft. I did a 225 evinrude last summer that I got a sawzall under the tiller after breaking up the power head adaptor. we were replacing the midsection anyway cause it broke, anyway we never did get the shaft out of the crank. we finnaly bored it out with a lathe and found the splines were eat off anyway. maint only costs if its not done. I have never seen a WELL maintained engine that would not come apart. so to answer your question. cutting the shaft and reshimming the pinion with a new shaft. shaft is about 400 labor to cut it and replace it is about 6 to 8. labor to replace the crank is about 35 hours if all the steps are followed. if all the steps are followed you will assemble and disasemble the engine 5 times while checking bearing clearences. is the motor really worth it and does ypour shop have the tools and facilities to tackle this? good luck and keep posting PS make sure you tell the guy you did not stick it. Hopefully you just missed a bolt someplace.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Got a stuck drive shaft seal cap that won't come off-93 48 ba_50 Johnson & Evinrude Outboards 8 January 31st, 2007 04:52 PM
94 130 hp 2 stroke Yamaha crank and piston ferrariman Yamaha & Suzuki Outboards 2 September 12th, 2006 12:00 PM
I did it this time: Drive Shaft Stuck in Engine FAV453 Johnson & Evinrude Outboards 4 November 26th, 2005 09:11 AM
Merc 110 9.8hp Crank and drive shaft Encorp Mercury & Mariner Outboards 4 April 22nd, 2002 08:20 PM
'83 Johnson 15hp - Drive shaft stuck in Power head kenb11 Johnson & Evinrude Outboards 1 July 12th, 2001 08:45 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
