longshanks
Thread starter- Joined
- Jun 12, 2006
- 188
Hi there<br /><br />I have recently purchased a 1998 outboard Merc 45 Jet (60hp powerhead). Although the motor appears to be in very good shape, and the seller states the motor was a very 'good runner', I am concerned about a couple of things... <br /><br />Compression tested evenly across all 3 cylinders at approximately 95. However, this test was done with the motor 'cold'. It has probably been run once (recently) in the last 3 years. Is this compression too low? Should I be concerned?<br /><br />After replacing the spark plugs, it is obvious that there is no spark on the top plug. The owner states this has not been a problem in the past. <br /><br />Lastly, the electric start turned the motor over fine while we tested the compression, but now it does not want to start, although the battery looks fine. <br /><br />I know that the motor has only been run 3-4 times in the past 3 years, but I suspect that it has run on 'old' gas for the last couple of outings. Prior to purchas by the previous owner, it would have only had 3 years of use. Should I be concerned about the symptoms above, or ??<br /><br />thanks for your help<br />longshanks
