Re: '83 merc. 6cly. stutters between 1500-200rpm
Did as you suggested and the boat ran fine in the shop under the muffs, but when I put it in the water and under pressure it planed and then cut out and then was only able to run it at 1500 rpm after that and nothing more. Can it be that the stator is toast or is there something else I am overlooking?
