  #1
Old February 24th, 2004, 10:46 AM
bonitoman bonitoman is offline
Default 130 yamaha backfires on flusher with flush muffler
I rebuilt my 130 yamaha and it has 2 hours idling on the flusher. I am ready to go for a ride on the river. I also have one of those flush mufflers that create back pressure simulating it in the water. Plus some of my neighbors don't like the sound of outboards. So after 15 years of running them I bought a flush muffler. My question is that I set the pilot screws at 7/8 ths and then 1 1/8 trying to richen the mixture thinking it is backfiring because it may be lean? Still no change. I have 135 compression and spark on all 4. All are firing. When i pull the plug wire on #3 there is no drop in rpm like the others. That does have spark. I am running double oil for the break in. I picked up this motor blown. The engine runs cool. Originally #4 was blown when I got the engine. Now thats great. I rebuilt the carbs and put a new diaphram kit in the fuel pump rebuilding that. Any suggestions apprecited. Thanks John
  #2
Old February 24th, 2004, 02:11 PM
Default Re: 130 yamaha backfires on flusher with flush muffler
Pick up timing at idle is set at 5 degress atdc and wot is set at 20 btdc. I have a new plastic omc fuel filter on instead of the yamaha since I have a dozen omc fuel filters laying around. All the fuel line around brand new connected with the black fuel tie wraps.
  #3
Old February 24th, 2004, 03:31 PM
rodbolt rodbolt is offline
hello double check the idle circuits on the top carb. the tiny jets in the fuel bowl can become clogged with anything. is this backfire from the exhaust and sounds like a bang or is this back fire like a deep cough and makes the motor jerk? you may have a restriction in the idle circuit. a lean backfire in a 4 stroke causes flame to pop out of the intake/carb shutters. a lean backfire in a 2 stroke with reed valves gets trapped in the crankcase and tries to move the piston against the compression. good luck and keep posting
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Is there a way to permanent mount an engine flusher on older Yamaha? smonty Yamaha & Suzuki Outboards 0 November 18th, 2006 10:14 PM
Where to buy a flush muffler? pfistey1 Non-Repair Outboard Discussions 5 May 28th, 2004 12:36 PM
flush muffler gator79 Non-Repair Outboard Discussions 8 May 12th, 2004 06:22 PM
Flush Muffler chadchurchill Non-Repair Outboard Discussions 4 April 22nd, 2004 10:54 AM
Yamaha 130 overheat alarm when on muff flusher Davidandkerrie69 Yamaha & Suzuki Outboards 1 April 7th, 2003 07:26 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
