I need help with getting the shifting adjusted correctly and maximun throttle on this 850.The motor doesn't want to respond after engaging in fw until almost into the 9 0'clock postion on the control handle. This holds true for the engine speed as well. I want to make sure both cables are adjusted correctly. When put into reverse, the motor makes a "ratcheting" sound. I don't believe anything is wrong with the l/u. Thanks.
