  #1
Old February 18th, 2004, 12:39 PM
SmokinBarrel SmokinBarrel is offline
Default '01 Yamaha 50 hp - crank but no start???
2001 Yamaha 50hp. For some reason the motor will not crank over!! I've checked everything leading to the gas filter: Gas tank, bulb, line, connections and everything is working! I was told that there is a "needle" in the carberator that might be stuck not allowing gas to feed to the carbs?? Another thing I noticed, I was putting the boat in the water, and when it wouldn't start, there was no oil in the water from flooding the carbs? Usually, when you flood the carbs, oil leaks to the water surface.....none! Any suggestions??? Reason I ask.....I know it's something simple, and I hate to spend $200 - $300 dollars on repair or something simple. Anyway, thought I'd try askin first. Any help would be appreciated! One more thing, could it be the spark plugs? I'm not sure, but it was running, and then it wasn't!! Furthermore, not 2 months prior to this it started, and I ran it for 5 minutes.....it was a bit hard to start, but I got it started.Thanks in advance for any advice
  #2
Old February 19th, 2004, 08:04 AM
Elmer Fudge Elmer Fudge is offline
Default Re: '01 Yamaha 50 hp - crank but no start???
Do a compression test,check for spark and post results P.S also check the kill switch
  #3
Old February 19th, 2004, 09:08 AM
zzzzz zzzzz is offline
is your safety lanyard on ??(gets everybody at least once !)
  #4
Old February 19th, 2004, 01:39 PM
rodbolt rodbolt is offline
hello post a model this could be one of many 50 hp models made in 2001. could be 2 stroke or 4 stroke. we need to know. post back and we can try to help
  #5
Old February 19th, 2004, 05:11 PM
I've checked everything. All looks good, but no fire. Oil injected, 2-stroke. Thanks for the input.
  #6
Old February 20th, 2004, 01:45 AM
hello remove the carb drain screws. if you have a carb with no fuel in it due to a needle stuck shut you will see it cause no gas will drain from it. extinguish all smokes and disconnect the battery before flushing and wash the cowl with soap and water and allow to dry. gasoline is an incredibly dangerous product that we take for granted to often. good luck and keep postingPS on some yamaha engines if the manual choke gets pushed in to far it locks the choke open.
  #7
Old February 21st, 2004, 06:14 AM
Hoggy Hoggy is offline
Quote from rodbolt ...PS on some yamaha engines if the manual choke gets pushed in to far it locks the choke open. That's for sure, found this out through trial and error ... ref 55hp Yamaha Original 2/stroke motor :o (
  #8
Old February 25th, 2004, 07:54 AM
Aaaannnndddddd the problem was......water in the tank! F**k! Can you believe that! I didn't think that was it, but it was. We hooked good gas up, and she fired right up!! Whew! That damn water, what a pain in the arse! Any suggestions as to minimize water or eliminate it in the tank!-Dennis
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
MTD (yardman) 1990 14.5 HP....won't start...won't crank... Manipulator Non-Boating Technical Topics 6 July 5th, 2006 05:52 PM
Crank, no start 1980 4 cyl 80 hp dctucker Mercury & Mariner Outboards 2 June 30th, 2006 03:39 PM
1973 Mercury 402 will crank but won't start goaskbudge Mercury & Mariner Outboards 0 July 26th, 2004 04:02 PM
crank won't start sea trout Non-Repair Outboard Discussions 4 September 19th, 2002 04:49 AM
crank but won't start 140 evinrude sea trout Johnson & Evinrude Outboards 2 August 29th, 2002 07:14 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
