hello
is this a 2 stroke or 4?
the normal causes are water in the cylinder or the lower unit is locked up. although I have seen the lower oil seal carrier on the 9.9/15 actually corrode and squeeze the drive shaft.
look at the spark plugs for rust. look in the gear case for water
good luck and keep posting
