tiffanynjon
- Jun 3, 2006
- 4
I have a 1987 115hp 6 cyl Mercury.<br />I just bought Boat and Motor, Little cold blooded at first, but Idle's fine @ 750 RPM without load and 1K RPM with load. Took it up to 5500 with no load - N.P. Runs great.<br />As soon as I put a load on motor, it started to stutter and hesitate @ 2400-2600 RPM. Like it was starving for gas and would not go over 2600 RPM. I put in New plugs, Premium mixed @ 50:1, checked filter. The problem only exists when under load.<br /> <br />Someone mentiond an upperband Stator? Had to look up what that was
<br />How do I test for balanced voltage on Stator's, Could that be problem? If so. What should the voltage read? Could it be another problem?
<br /><br />Any suggestions would be extremely appreciated. <br />Thanks,
