  #1
Old January 14th, 2004, 07:38 PM
gator79 gator79 is offline
Default yamaha 130 carb cleaning
I have a pair of 1989 130 hp yamahas. one will idle fine but bogs and sputters under load. It has been sitting for 5 months and probably needs the carbs cleaned. are there any special tricks to look for on theese carbs? I am a certified auto tech and have rebuilt auto carbs before, but it has been a long time, they quit using them about 20 years ago. If anyone has any tips or advice or thinks this may not be the problem please let me know.thanks,Mark
  #2
Old January 15th, 2004, 01:57 AM
seahorse5 seahorse5 is offline
Default Re: yamaha 130 carb cleaning
Just like with auto carbs, use care to take them apart and clean out every passageway. First obtain the correct service manual and study closely the adjustment and synchronization section, as those are important for drivability.Don't have a heart attack when you see the Yamaha carb kit prices and take your model number whith you to be sure to get the right ones.There is an old service bulletin about drilling out the blind passageway from the fuel inlet fitting to the float valves. Ask your dealer to copy it for you. It is also reprinted almost every year in the annual Marine Technical Guide. In some cases, rust from the steel screws in the fuel pump, build up and cause intermittent restrictions. If the fuel pump is original, replace it.
  #3
Old January 15th, 2004, 02:14 AM
rodbolt rodbolt is offline
hello yep what seahorse says. be hesitant about drilling the cleanout passage. do it only if nessasary. 99%of the problems are in the idle pick-ups in the fuel bowl. that is where the solids settle as the feul evaporates. I dont recommend soaking the carb throttle body assy in a dip solution. I use CRC 06064 cleaner. the bowls can be soaked for a bit if nessasary but usually I can clean 2 carbs with one can. buy new pumps and the job is complete. good luck and keep posting
  #4
Old January 15th, 2004, 02:26 AM
That rusty over-torqued old RODBOLT is correct. Don't worry about drilling out the passage unless the carbs are very dirty, or if you end up with an intermittent power loss while running. Not every carb needs it, I should have made that more clear.The idle jets in the bottom of the float bowls are very small, and most of the time, frozen in place. Use a spray carb cleaner, or better yet, something like Bombardier Engine Tuner, or another "decarbonizer" to soak inside the float bowl overnite. It is not powerful enough to strip the sealing compound off the aluminum, but will clean out gummed fuel deposits beautifully.
  #5
Old January 15th, 2004, 03:06 AM
Rodbolt, are you talking about replacing the fuel pump also?i just bought the boat and the previous owner said the fuel line at the motor was sucking air and he replaced the line and fitting. has anyone heard of that? I am not real sure of the repair history of theese motors so i will go ahead and replace the fuel and water pumps. I have the yamaha factory service manual but it does not mention carb syncronizing. what are your thoughts on removing oil injection. if anyone has any car or truck questions I will be happy to answer them. thanks for everyones input.
  #6
Old January 15th, 2004, 03:38 AM
Fuel pumps are Yamaha's weak point. Replace it as it is a reasonable $39.
  #7
Old January 15th, 2004, 08:50 AM
wtrojan wtrojan is offline
Quick connect fuel line fitting sucking air? Well gator, been thereÂ… Engine similar to yours 130s, yamaha V4 from early 90Â’s. Female partÂ’s gasket got dented and allowed the air getting in with higher revs. Also, couldnÂ’t agree more with the fuel pump opinions above. In mine, the valves were the weak point, so if you can change the pump without hesitation.
  #8
Old January 15th, 2004, 09:11 AM
should I replace the diaphram or the entire fuel pump?
  #9
Old January 15th, 2004, 11:09 AM
Changing the diaphragm wonÂ’t hurt, but if the pump inner checkvalves are bad, this will not solve the problem. IÂ’m not sure if you can get the valves and a diaphragm in a kit, if not, the whole pump assembly replacement would be recommended.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Instructions for 6hp Yamaha 4 Stroke Carb Cleaning? Summer Breeze Yamaha & Suzuki Outboards 1 June 11th, 2005 04:06 AM
Yamaha carb cleaning and adjustment Millmaker Yamaha & Suzuki Outboards 4 July 29th, 2004 11:49 AM
carb cleaning Javelin 353 Johnson & Evinrude Outboards 4 January 4th, 2004 04:22 PM
carb cleaning stocky Other Outboard Brands 0 August 21st, 2002 06:51 PM
carb cleaning johnntab Non-Repair Outboard Discussions 4 March 13th, 2002 03:02 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
