I picked up a 40 2 cylinder thought the motor was in good condition but now I'm having second thoughts. <br /><br />This is whats happening, <br /><br />Problem 1 Motor turns over, kinda slow. I found some corroded wires at the front of the motor which should still hold a alright current but I will be replaceing at soon as I know it will start. <br /><br />Problem 2, I had a hard time getting spark, I pulled the plugs out grounded them on the block and ground wire and I got spark once, came back to the motor a few days later nothing was touched and now I can't get spark again?<br /><br />Question? Are the 79-83 40hps all the same? I found some info that said that before but I can't find it need to check if that is correct.<br /><br />If someone could give me some advice that would be great.<br /><br />Thanks
