  #1
Old January 10th, 2004, 07:43 AM
everett clark everett clark is offline
Default Yamaha wiring harness
I have just bought a rebuilt 250 Yamaha 1991 TUPP. I have a 1989 200 Yamaha currently on boat. Question is can I use my current wiring harness and gages now instaled plugs look different. there is one which is Square. Is ther is an adpater out there or will I have to buy new or used wiring harness??? Who may have ?Thanks Everett
  #2
Old January 10th, 2004, 08:13 AM
JoeW JoeW is offline
Default Re: Yamaha wiring harness
I am not an expert in this field, but I too am trying to wire a different O/B on my boat. I bought a 1998 hull and I'm trying to wire a 1988 Mercury o/b. I'm using the harness that was originally on the o/b. My hull was a theft recovery that I bought at a local salvage yard. The theives had stripped the boat o/b and had cut the harness in several places. I was told that I would need to custom make my harness to fit my o/b to my hull. I bought a harness on e-bay that I plan on using bits & pieces of ($36.00). I would start with the manufacterer of the motor. Yamaha may be able to set you of with the portion of the harness that fits the motor end. You might also want to check with the manufacterer of the hull. If it's not too old, they may still have the harness in stock, or they may be able to point you to a surplus dealer that handles them. Starcraft was little help to me.I hope this helps.-Joe
  #3
Old January 10th, 2004, 12:04 PM
BRIAN03 BRIAN03 is offline
The main harness is the same. The oil tank wire harness is different. The harness is cheap about 25.00 or Suzuki uses the same harness for 20.00. You can even make that harness if you buy the ends.
  #4
Old January 11th, 2004, 06:42 AM
BRIAN03Thanks for you help! Is the oil tank connection the Square one on the 250? Can you steer me to a source to buy the harness? Don't worry I want ask you to install it! If I had the wiring diagram of the 250 I could fabricate one, but just bought the engine yestrday and have not found a manual localy. may have to order one.again thanks for your help!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1988 Mercury 70hsp wiring harness/control wiring ricklackey Mercury & Mariner Outboards 5 July 12th, 2007 11:19 AM
Yamaha wiring harness drbobp Yamaha & Suzuki Outboards 4 October 16th, 2004 06:33 AM
elec short in wiring harness yamaha ferg57 Electrics, Electronics and Trolling Motors 0 September 29th, 2004 10:38 AM
Re-wiring Center Console - ignition harness - tilt harness Kesh Boat Topics and Questions (not engine topics) 2 May 22nd, 2004 03:41 PM
Yamaha remote wiring harness stevelambert Yamaha & Suzuki Outboards 0 January 28th, 2002 06:24 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
