  #1
Old January 5th, 2004, 10:19 PM
stringbag stringbag is offline
Default Yamaha 40 overheating control test?
I have a 1984 Yamaha 40HP (twin cylinder)in tidy order. Engine runs well but the overheat sensor and engine rev limiter cuts in regularly as soon as the engine gets a few minutes running at more than 1/4 throttle.Engine temp feels okay (the touch test on the block), water pump impeller is new, tell tale pressure is great even at idle, so I doubt I have a cooling water problem. Maybe wrong with this though...My thought is I have a faulty engine rev limiter and temperature sensor. I have no idea how to test this to check it out. Any ideas and suggestions welcome.
  #2
Old January 30th, 2004, 09:56 AM
Jammu Jammu is offline
Default Re: Yamaha 40 overheating control test?
Take the thermostat out an try to run it without it. If it works now, then change the thermostat.
  #3
Old February 2nd, 2004, 04:27 AM
jim dozier jim dozier is offline
If the engine isn't overheating as you suggest, removing/or replacing the thermostat won't help. Besides, you can test a thermostat in a pot of water on the stove with a cooking thermometer. What you really need to do is confirm that the engine is or is not overheating. Infra red thermometers are available for a reasonable price at Radio Shack. You point them at the cylinder head or anywhere else. Or you can get hold of a heat stick crayon from a dealer and mark the engine for temperature. If its not overheating, you could replace the sending unit for the alarm. They do sometimes give erroneous alarms. You should go to the bottom of this web page and buy a manual if you don't already have one.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
hot wiring to test electrics on 130 hp with no control box a_bullfrog_a Force & Chrysler Outboards 0 September 26th, 2005 07:47 PM
Throttle control - Continuos Beeping - Not Overheating BassNBooze Mercury & Mariner Outboards 0 April 25th, 2005 05:30 PM
Question about control box horn test Mark42 Johnson & Evinrude Outboards 10 December 14th, 2004 04:54 PM
1982 90 HP Mercury, 6 cyl, engine overheating, compression test dmixon Mercury & Mariner Outboards 1 July 24th, 2003 04:15 PM
Test procedure for '70 spark control, 65HP Merc mike44471 Mercury & Mariner Outboards 0 September 5th, 2002 08:06 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
