  #1
Old November 28th, 2003, 02:54 PM
bonitoman bonitoman is offline
Default disconnect oil injection on 98 90 yamaha
What needs to be done to disconnect the oil injection system on a yamaha 90 hp. I will premix just like i have done on all omc engines. I see the electical connections that need to be disconnected. What on the pump or block needs to be plugged or removed. Thanks.
  #2
Old November 29th, 2003, 01:16 AM
BRIAN03 BRIAN03 is offline
Default Re: disconnect oil injection on 98 90 yamaha
WHY Yamaha has made the best oil injection system on the market. The oil is injected in to the intake manifold for a reason. Yamaha has spent alot of money designing this system. It works great and supplys oil to engine based on throtle position. Would you pull the fuel injection system off your car and put a carb back on it. Other than a sensor problem once an while this system works well. You will use alot less oil too.
  #3
Old November 29th, 2003, 03:02 AM
rodbolt rodbolt is offline
hello yep what he says. I would not pull the precision blend system from that yammy. maintain it service it look at the clip that attaches the link arm to the pump. some white ones in the 98 99 had some problems with cracking. but overall its a very rugged and reliable system that will allow for some carb leanout without scuffing pistons. I would recomend replacing the fuel pump diaphram every 3 years . do this before it fails. a leaky diapham will waste a pistion on most oil injected motors due to the raw unmixed fuel diluting the oil. so if I were maintaing this motor I would sweat the oil tank cleaning once a year and the fuel pump. both are totally simple.both can make you frown. but I like oil injection due to the more precise oil control. most premixers have a tendancy to give a little extra. extra oil can do almost as much damage as no oil, it just takes a bit longer. good luck and keep posting
  #4
Old November 30th, 2003, 01:27 AM
I still want to disconnect the oil injection system. What needs to be done. I know yamaha makes great engines. I just do not like oil injection systems and will always premix.Thanks
  #5
Old November 30th, 2003, 02:32 AM
hello if you wish what I would do then is remove the pump leaving all lines attached. withdraw the pump driveshaft. reinstall the pump and lines. remove the oil resevor and cap off the line at the pump . unplug the wiring. test the overheat alarm and go like mad. you may find the motor harder to start due to the oil in the fuel. you may have to open the fuel mix screws 1/8-1/4 turn. dont let fuel sit over 30 days in the bowls. if those touchy little mikunis or kiev's run just a tiny bit lean due to trash or oil varnish. POOF no piston skirts. good luck and keep posting.
  #6
Old November 30th, 2003, 03:26 AM
Thanks Rodbolt for the info. MY question is for the pump driveshaft. I see a driveshaft in the engine that comes out of the block and in the pump itself looks like a drive shaft and a gear with teeth. Which component do I remove? Thanks Also do I need to cap the lines oil lines that go to each carb.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
How to disconnect oil injection willyp Mercury & Mariner Outboards 4 September 23rd, 2005 02:58 PM
disconnect oil injection ? g6ips3y Yamaha & Suzuki Outboards 6 August 2nd, 2005 09:16 AM
disconnect oil injection???? crazy charlie Johnson & Evinrude Outboards 6 March 16th, 2004 11:25 AM
Oil Injection - Disconnect or Not steam_mill Mercury & Mariner Outboards 1 November 1st, 2003 03:23 PM
disconnect oil injection on yamaha 130 bonitoman Yamaha & Suzuki Outboards 0 January 17th, 2003 11:06 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
