  #1
Old November 14th, 2003, 01:45 AM
huanca huanca is offline
Default Yamaha Lower Unit pressure test 11 psi leak
5 seasons, 250 run hours on Yamaha 140BET in saltwater. Off season, ran weekly in fresh water for 10 minutes. 2x yearly lower unit oil changes, golden color in and out always. A little shavings on the magentic plug. Did a pressure test with lower unit without oil(supposed to hold 14.2 psi for 10 secs) and at 11 psi leaks started at the shaft seal. Oil still comes out like new. Got the new seals for $ 4 each (2 needed) from Yamaha. Should I change seals?
  #2
Old November 14th, 2003, 01:58 AM
rodbolt rodbolt is offline
Default Re: Yamaha Lower Unit pressure test 11 psi leak
hello I assume its the propshaft that you see leaking. that is a tough call. yammaha puts both sealing lips facing out. the older v4 and v6 units only tested to 2.2 pounds.the newer jumped to the 14.2. you should also buy the bearing carrier oring and remove the carrier to change those seals. although I have done it without it. OMC makes a tool that allows seal changes without removing the carrier as well.good luck and keep posting.
  #3
Old November 14th, 2003, 04:59 AM
Capt Ken Capt Ken is offline
Ensign
Yep, don't attempt to change the seals without removing bearing carrier. If you slip and scar the propshaft, you just screwed up. I would probably leave well enough alone and just keep a close eye on the oil condition. If you see it change or detect some water, then address the problem.
  #4
Old November 14th, 2003, 04:26 PM
wtrojan wtrojan is offline
Hey huanca, finally someone with the same engine as mine! Moreover, from a place much closer than others. These engines just donÂ’t appear on this board (not sold in US, they are the same design as others yamaha V4Â’s, though). What year is yours? How do you like it? If you wish, we could change some info by mail, let me know. Take care!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
lower unit past pressure test, oil is still milky ggreen Johnson & Evinrude Outboards 8 July 21st, 2004 07:31 AM
lower unit pressure test AtlDawg Johnson & Evinrude Outboards 1 April 16th, 2004 04:52 PM
pressure test lower unit sawcat Johnson & Evinrude Outboards 7 March 12th, 2004 04:45 PM
Leak test lower unit cloumar Force & Chrysler Outboards 4 January 5th, 2003 11:01 AM
lower unit pressure test? leeman Yamaha & Suzuki Outboards 1 April 11th, 2001 05:02 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
