Hello
can you be more specific. I have no clue as to a top unit drain? can you post what they did for a 100 hour service? the yamaha owners and service guides really dont have any maintence other than oil change for the lower unit and the power head. no valve adjustments or anything. if it was overfilled with engine oil it may force some out.
my guess is that some was spilled and it is still dripping out from the engine lower cowling. dang engineers screwed us again. its very difficult to remove a filter mounted on its side without making a mess. try the v6 sometime.
anyway look very close at the oil level then look on the stbd side and see if any oil was spilled. if not then further investigation will be nessasary.
good luck and keep posting.
