Hello
the jet unit has a standad type insert and plate arrangement almost identical to an outboard. the jet pump allows water to the engine seawater pump. from there it travels up the tube to the power head just as any outboard. check the tell tale hose and nipples for restrictions. low water pressure could mean a removed or defective t-sta a removed or defective pressure valve or the seawater pump is melted. this happens a lot on jets. takes 30 seconds of dry running to toast the seawater pump impeller.most jet failures we see here are due to slow speed/shallow water operation. either the jet lifts up a rock or other unpassable obstruction or it sucks up so much sand the engine cooling system gets clogged. I reccomend jet engines to have the head removed periodically and the passages cleaned if run a lot in shallow water. most over heated jets are due to melted pumps or excessive wear on the jet impeller causing cavitation and feeding the seawater pump a mixture of air and water causing the seawater pump impeller to cavitate and the engine gets hot.
good luck and keep posting, a jet has its own peculiar problems that props dont. be aware of them or life will be sad.
