1989 mercury 8 hp water pump replacement
felderlostnspace
i have removed the 3 bolts to drop the lower unit,but the unit will only drop about an inc.shaft seems to be held in place up in the engine.is there a clip,key,pin,etc that i am over looking?any help would be great.thanks in advance,Bill
Laddies
Banned
Re: 1989 mercury 8 hp water pump replacement
There the shift rod under the carb
felderlostnspace
i'll look under the carb after church in the am.i looked there but did not see anything but not quite sure what i am looking for.thanks for the response.i'll let you know how it turns out,thanks, Bill
felderlostnspace
Laddies,thanks for the help.it was under the carb as you said.i had taken that linkage part way off 2 days ago and put it back together because i did not know what i was doing.i removed the linkage and the lower unit slipped right off.thanks again for the help.Bill
