Re: Looking at Purchasing 87' 60HP Mercury
Those compression values can't be correct, unless it has been modified considerably. Typically they fall somewhere between 110 and 150psi max. I've never heard of one that high. Recheck it, and make sure all 3 cylinders are within 10% of each other, and all over 110 psi. Any less, and it is probably close to worn out.<br /><br />Parts are readily available for that motor.<br /><br />If well maintained it should be a great motor. Some prefer the 4 cylinder motors over the 3 cylinder.<br /><br />Check the lower unit for signs of moisture and smooth shifting. Check the spark to see if it is consistent and strong on each cylinder. Should jump a 3/8" gap.<br /><br />If you can, take it for a run on the water and through all speed ranges. Shift it, and make sure the gears sound ok.<br /><br />For a pontoon boat, you will want a smaller pitch prop. Be sure to aim for 5500rpm at WOT. If it is overpropped it will lug the engine and result in damage.
