  #1
Old October 7th, 2003, 02:19 PM
GUIDO2 GUIDO2 is offline
Default YAMAHA 84 OIL INJECTION FILLS LOWER CYCLINDER
I have a 1984 Yamaha Oil Injection .Here we go if disconnect the gas and let stand and do not use the engine for a couple of weeks, the lower cyclinder fills up with oil. I don't know if this is created from the heat from the sun or what. I brought this engine in and had them look at it and they said that the Oil Injection was working fine, but they did mention that if I did leave the gas hooked up to the engine this could be the results..The engine runs fine after I clean the cyclinder...I did not run engine out of gas...any help would be appreciatedthanks
  #2
Old October 8th, 2003, 04:52 AM
mrn714 mrn714 is offline
Default Re: YAMAHA 84 OIL INJECTION FILLS LOWER CYCLINDER
Sounds like the oil injector lower valve is leaking. You will need a service manual to repairs.
  #3
Old October 8th, 2003, 07:59 AM
I agree with what you are saying, but on this engine, the Oil discharge comes directly from the combination Oil/Gas Pump....If the pump is not running how would the oil manage to leak?I really appreciate your help on this. Like to see what you have to say.Thank You again
  #4
Old October 21st, 2003, 05:17 PM
BRIAN03 BRIAN03 is offline
The oil pump is worn out. It is pushing oil thru the pump when it is sitting. The oil tank is above it and will gravity feed thru the pump. You need a new oil pump.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Crankcase fills with gas mick25170 Mercury & Mariner Outboards 1 May 24th, 2006 02:43 AM
Grounding Plastic Gas Fills Reel Poor Boat Topics and Questions (not engine topics) 1 February 26th, 2006 06:24 AM
water in cyclinder ferryrat Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 9 July 11th, 2005 07:10 AM
water in cyclinder russeller Johnson & Evinrude Outboards 3 June 20th, 2005 10:09 AM
1988 48hp evinrude { lower cyclinder} bfast1fishing Johnson & Evinrude Outboards 1 October 6th, 2004 06:41 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
