  #1
Old October 6th, 2003, 08:15 PM
KNOTTY THOTS KNOTTY THOTS is offline
Default Yamaha 150 engine block serial numbers
Does any body know if you can match the engine serial number to the engine block number. My shop said it replaced my power head under warranty when the crank shaft broke. But there is red gasket sealent on the side of the block, at the joint of the crankshaft. It does not look like a standard maufacturing seam.Please Help.
  #2
Old October 8th, 2003, 04:46 AM
mrn714 mrn714 is offline
Default Re: Yamaha 150 engine block serial numbers
If you crank broke, the entire block would need to be broken down, so sealant would not be something I would worry about. Only the motor has a SIR #. The block, power head etc, are only identified by part number.
  #3
Old October 8th, 2003, 07:59 PM
Thanks Thom, but I was not worried about the sealant. It's just since it was repaired I have had lots of problems. I was told when the crank was repaired, that Yamaha replaced the power head. So I think they repaired it and kept the new power head for themself. When I took the engine apart this past weekend I found that same damaged. The piston and head had been damaged by flying metal in the cylinder. This was not why I was repairing in the first place. A differnt dealer found damage to # 6 cylinder because the o ring on the oil pump was not installed right. Also done when the crank was fixed.By the way there are etched numbers on the block.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Are any of these Serial numbers? SonicV6 Mercury & Mariner Outboards 5 July 29th, 2006 12:31 AM
Engine serial numbers Gary H NC Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 May 4th, 2006 06:06 PM
serial numbers Tammy Massey Mercury & Mariner Outboards 1 October 21st, 2003 07:08 AM
SERIAL NUMBERS smoker craft dave Mercury & Mariner Outboards 3 October 13th, 2003 10:35 PM
What can be learned from OB engine serial numbers? Jonah Mercury & Mariner Outboards 2 July 5th, 2002 09:13 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
