  #1
Old October 4th, 2003, 06:22 PM
Larry Sapp Larry Sapp is offline
Default 86 Yamaha 70 hp shakes at low rpm in gear
I just purchased a 86 Yamaha 70 hp , it idles fine in neutral but when I shift into forward it shakes at low rpm's ! My question , is this normal for this engine ( 3 cyl. )? It smooths out fine once the throttle is increased and runs good WOT... TIA L.E.S.
  #2
Old October 4th, 2003, 06:50 PM
rodbolt rodbolt is offline
Default Re: 86 Yamaha 70 hp shakes at low rpm in gear
Hello its hard to estimate excessive shaking without seeing it. some of those motors shook some when idleing. you may try moving the carb pilot screws in or out 1/8 at a time and see if it smooths out any. keep posting and let us know
  #3
Old October 5th, 2003, 10:11 AM
Thanks Rodbolt for your responce ! Here's a little more info , the bottom carb was leaking so I to it to repair shop ,they cleaned carbs and replaced water pump impeller... (impeller was insurance on my part). I would think the carbs would be adjusted correctly at the shop but I doubt they engage shifter while running.....As I said in my post the engine runs good so maybe this is normal for this engine . I will purchase a Clymer manual before attempting any tweeking on my own . Thanks Again L.E.S.
  #4
Old October 6th, 2003, 04:49 AM
lonewolf5347 lonewolf5347 is offline
L.E.S.I have a 90 hp yamaha 2003 and it seems that at idle there is a liitle shaking to the engine but onces in gear the problem is gone.What I did to correct the problem was to increase the idle speed a little and increase the low speed jets or pilot screws.Factory setting on the low speed jets were around 1 1/2 turns out now it seems to run great at idle with about 1 3/4 turns out on pilot screws
  #5
Old October 7th, 2003, 03:29 PM
Thanks Lonewolf5347 for your reply and info.... L.E.S.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
motor has the shakes! b.gagnon Force & Chrysler Outboards 1 August 24th, 2005 10:18 AM
engine shakes diggs Johnson & Evinrude Outboards 3 August 17th, 2005 05:22 AM
60 johnson shakes fish68 Johnson & Evinrude Outboards 2 August 13th, 2005 08:36 PM
will not idle in gear/ hard starting/shakes mcflteng Force & Chrysler Outboards 3 August 29th, 2003 06:33 PM
Engine Shakes gallma Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 September 11th, 2002 09:12 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
